BIMCHECKDETAILS command
Inspects the BIM Project details and their references.
The command opens a command context panel that lets you see which BIM Project detail has references in a Project's 3D model/sheet (lists its references, if any). It also checks the links between all detail references/layouts and their DWG files.
Method
Use the command with a Project's 3D model or sheet file open.
The command context panel displays the details in tree views, with each node representing a detail. For each detail, the number of the detected references is displayed near the detail's name. Expand a node to see the references.
- Identify detail references by highlighting in the drawing the ones selected in the panel (for 3D models/sheets).
- Update links between detail references in the model or detail layouts on sheets and detail DWG files (for 3D models/sheets).
- Insert on the current sheet layouts of BIM details referenced in the model (for sheets).
- Update detail layouts inserted on the current sheet (for sheets).
Right-click a detail to display a context menu with actions specific to the current file.
- 3D model:
- Details with references
- Details without references
- Lists all project details that have references in the 3D model.
- Lists all project details without references in the 3D model.
- Sheet:
- Details with tags and layouts
- Details without tags and layouts
- Lists all details on the sheet that have tags and layouts. Expand a node to see the detail references/layouts.
- Lists all details on the sheet that do not have tags and layouts.
- Context menu options:
- Link a detail file
- Allows you to reassign a detail file to a detail/a detail layout in the database.Note: The option is available only when the detail file is missing.
- Insert detail layout
- Lists the names of the layouts in the selected detail's file and allows you to insert one the sheet.
Type in a layout name, press Enter, then select the insertion's base point and second point.
- Update layout
- Updates the inserted detail layout.
