BIMCOPY command
Creates copies from the planar faces of 3D solids.
BricsCAD BIM
Icon:
Creates copies from the planar faces of 3D solids, and the sides and ends of linear solids.
Method
Specify a distance to create copy.
Note: You can specify a distance in the dynamic dimension field and right-click to create a single copy.
Options within the command
Copy
Creates copies.
Repeat
Repeats the copy using the same displacement.
Note: Move the cursor in the displacement direction. The further you move away from the source solid, the more copies are created.
Number
Creates a number of copies you want to have in your model.
Accept
Accepts the current distance you entered in the dynamic dimension field.
