BIMCURTAINWALL command
Creates a curtain wall.
Icon:
Creates a curtain wall, as a block, from the face of a 3D Solid.
Method
Select a face and create a grid.
Options within the command
- Length U panels
- Sets the length of the panels in U direction (height).
- Length V panels
- Sets the length of the panels in V direction (width).
- Number U panels
- Number of panels in U direction (rows).
- Number V panels
- Number of panels in V direction (columns).
- Width
- Defines the width of the curtain wall frame, mullions and transoms.
- Depth
- Defines the depth of the curtain wall frame, mullions and transoms.
- Glass thickness
- Defines the thickness of the glass panels.
- Connections type
- Defines the type of the connections between horizontal and vertical mullions.
- sTraight
- Creates a straight connection.
- Smooth
- Creates a smooth connection.
- Nodes
- Creates a node connection.
- Delete defining entities
- Whether the selected source entity is retained or deleted depends on the value of the DELOBJ system variable.
