BIMDISTRIBUTIONSYSTEM command
Creates or edits a BIM Distribution system group.
Method
Enter an existing distribution system name or a name for a new distribution system, then select the entities to add to or remove from the distribution system.
Note: Distribution systems created with BIMDISTRIBUTIONSYSTEM command are exported with IFCEXPORT command as IfcDistributionSystem entities.
Options within the command
- List distribution systems
- Lists in the command line panel all existing BIM Distribution System groups.
- Create a distribution system
- Creates a new group of BIM Distribution System.
- Show properties
- Allows you to edit the properties. The available properties are displayed in the command line panel.
- Ifc properties
- Allows you to edit the IFC Properties. The available IFC Properties are displayed in the command line panel.
- Delete distribution system
- Deletes the selected BIM Distribution System group.
- Creates a new BIM Distribution System group.
