BIMEXTEND command
BIMEXTEND command
Extends a wall.
Icon:
Method
The command extends a side of a wall that doesn't intersect other walls by automatically detecting the nearest wall to extend it to.
Select 0-1 entities/subentities
Select the part of the wall that should be extended.
Related commands
  • BIMQUICKBUILDING command
  • BIMQUICKDRAW command
  • BIMQUICKWALL command
  • BIMTRIM command
  • BIMWALL command
