BIMGROUP command
Creates or edits a Group with BIM elements.
Method
Enter an existing group name or a name for a new group, then select the entities to add to or remove from the group.
Note: Groups created with BIMGROUP command are exported with IFCEXPORT command as IfcGroup.
Options within the command
- List groups
- Lists all existing groups in the Command line.
- Show properties
- Allows you to edit the properties. The available properties are displayed in the Command line.
- Ifc properties
- Allows you to edit the IFC properties. The available IFC properties are displayed in the Command line.
- Delete group
- Deletes the selected group.
- Create a group
- Creates a new group.
