BIMPROPAGATECORNER command
Propagates details.
Icon:
Propagates details connected to three planar base solids (e.g. corners).
Method
Select at least three planar reference solids that form a 3D corner. The detail will be copied to similar corners.
Options within the command
- Select detail objects
- Select additional solids, blocks or faces to be included in the corner detail.
- yes, copy as Block
- This option is available only when detail objects are selected. A block is created from the selected detail objects, which is then copied.Note: The default block names are Block, Block 1, Block 2, ... You can rename blocks in the Blocks category in the Drawing explorer. See the EXPBLOCKS command.
- yes, plain Copy
- This option is available only when detail objects are selected. The detail objects are copied as is.
- No
- Exits the command without accepting the detail.
- Inflate first
- Expands the sensitive zone to include similar solids which are not connected yet in the model. The edges of the initially detected detail are moved outward over a specified distance.
- Save detail
- The Save Drawing As dialog box displays.
You are prompted to specify a file name to save the detail.
- Apply
- Accept or reject suggestions by clicking on the tick.Note: See the Apply option in the BIMPROPAGATE command.
