BIMRECALCULATEAXIS command
Recalculates and repositions the axis of linear building elements.
BricsCAD BIM
Icon:
Recalculates the axis of linear building elements and repositions it back on the center line of a linear element. When the command is run, select all linear solids for which to recalculate the axis.
Related commands
  • BIMADDECCENTRICITY command
  • BIMLINEARSOLID command
  • BIMPROFILES command
Related information
  • BIM linear solid
  • BIM Profiles panel
  • Structural steel
