BIMSETREFERENCEFACE command
Defines a reference and an opposing face to control the ply layout of a composition.
Methods
The reference face can be set manually by selecting a face. If the opposing face is parallel to the reference face, a suggestion for the opposing face is given and can either be accepted or be changed.
Note: If one of the plies of the composition has a variable thickness, the reference and opposing face can be non-parallel. In this case the fixed thickness plies are set out starting from the reference face, and the remainder of the solid is filled by the variable ply.
Solids without composition |
Multiply composition assigned Reference faces are either wrong or not found |
Attaching a composition Reference faces highlight |
Result |
Options
- Select manually
- Selects the opposite face manually.
