Select a wall, a wall-like solid or a linear solid. The BIMSLICEWALL command automatically defines the plane as a vertical plane, perpendicular to the length direction of the solid.
A blue line displays at the cursor, from the cursor to both ends of the solid, which allows to precisely indicate the slicing position dynamically.
