BIMTRIM command
BIMTRIM command
Trims a wall.
BricsCAD BIM
Icon:
Method
The command trims a part of a wall by automatically detecting other walls and using them as trim objects.
Select wall
Select the part of the wall that should be trimmed.
Related commands
  • BIMEXTEND command
  • BIMQUICKBUILDING command
  • BIMQUICKDRAW command
  • BIMSLICEWALL command
  • BIMSPLIT command
  • BIMWALL command
  • BIMWINDOWCREATE command
