BIMUPDATETHICKNESS command
Re-applies the overall thickness of a composition to the solid.
Icon:
Method
Select the solids to re-apply the overall thickness of composition to.
The command finds the broken connections (mitered/butted) between the selected solids and adjacent solids and automatically restores them.
Note: Make sure the KEEPCONNECTIONS system variable is turned On.
Accept/reject all restored connections or check connections individually.
Note: Only solids that need to be updated are processed.
Options within the command
- Symmetrical Update
- Updates the thickness symmetrically or with respect to the reference face. See also the BIMATTACHCOMPOSITION command article.
- Accept
- Accepts all automatically restored wall-wall connections.
- Reject
- Rejects all automatically restored wall-wall connections.
- Check individually
- Zooms in the view to each restored connection and lets you accept/reject it.
- Yes
- Accepts the restored connection. Select Confirm.
- No
- Rejects the restored connection. Select Confirm.
- Confirm
- Confirms the previous option selection.
