BIMZONE command
Groups Spaces into a zone.
Method
Enter an existing zone name or a name for a new zone, then select the entities (Spaces) to add to or remove from the zone.
Note: Zones created with BIMZONE command are exported with IFCEXPORT command as IfcZone.
Options within the command
- List zones
- Lists all existing zones in the Command line.
- Show properties
- Allows you to edit the properties. The available properties are displayed in the Command line.
- Ifc properties
- Allows you to edit the IFC properties. The available IFC properties are displayed in the Command line.
- Delete zone
- Deletes the selected zone.
- Create a zone
- Creates a new zone.
