BLMATERIALS command
BLMATERIALS command
Opens the Physical Materials dialog box.
Icon:
Opens the Physical Materials dialog box to create and edit material definitions in the library or project.
Related commands
  • MATERIALASSIGN command
  • MATERIALS command
Related variables
  • RENDERCOMPOSITIONMATERIAL system variable
  • RENDERMATERIALSPATH system variable
Related information
  • Physical materials
  • Physical materials dialog box
  • Render materials
  • Render materials panel
