BLOCK? command (Express Tools)
Lists the entities in a block definition.
Method
Enter a block name or press Enter to select a block in the drawing, then specify an entity type. The entity list is displayed in the Command line.
Related commands
  • BLOCK command
  • INSERT command
  • WBLOCK command
Related information
  • Express tools command overview
