BLOCKTOXREF command
Replaces all instances of a block with an Xref.
Icon:
Method
Select one or more block references to replace with Xref/s.
This command displays the Block To Xref dialog box.
Note: The block name for the Xref is generated from the file name. If an Xref (or overlay) with the same name already exists in the drawing, the block is replaced using existing Xref.
- Select the block to be replaced.
- Select block instances.
- Options.
Selects all block instances to replace.
Select particular block instances
Selects only particular block instances to replace.
Options
- Replace with conversion to Xref
ON: saves the block first and then replaces the block with the newly created Xref.
OFF: the block is replaced with an Xref.
- Ask for filename for newly created Xref
ON: the Save Block dialog box displays to save the block before replacing it with an Xref.
Note: If the selected block name is a dynamic block name and the Replace similar inserts option is On, all modified dynamic blocks are replaced by one Xref. If the selected block is an instance of a modified dynamic block and the Replace with conversion to Xref option is On, the new created Xref will contain the default (unmodified) dynamic block definition (similar with WBLOCK command which cannot save anonymous block definitions).OFF: a new drawing is created next to the original drawing with the same name as the block name.
- Replace similar inserts (e.g. modified dynamic blocks)
Note: This option acts like the BLOCKREPLACE command.ON: replaces all instances of a block and all its modified (anonymous) dynamic blocks.Note: If the Select particular block instances is On and a non-dynamic block is selected, all instances with the same block name are replaced with the Xref.Note: This option cannot be changed when the Replace conversion to Xref option is also On and Select particular block instances is selected, because multiple Xref files and multiple block definitions can be created for one block.OFF: anonymous (modified) dynamic blocks cannot be replaced with Xref.Note: If Select particular block instances is selected, only selected instances are replaced with Xref.
- Keep parametric block expressions
- Keeps expressions of the replaced block when the replacement block has parameters with the same names.
- Purge unreferenced block
- Removes unreferenced block instances.
