BMANIMATE command
Runs a quick animation of an exploded view and exploded view steps.
Method
- Open for edit the exploded representation using the BEDIT command.
- Launch the BMANIMATE command.
- Select Exploded view and define the first and the last steps for animation.Note: The command runs according to the values set with the BMEXPLODESTEPEDIT command.
- After finishing the animation, launch the BCLOSE command, to close the block editing session.
Options within the command
- paUse
- Pauses the animation.
- Play
- Plays the animation.
- Stop
- Stops the animation.
- pRevious
- Shows the previous step of the animation.
- Show
- Shows the next step of the animation.
- Finish
- Finishes the animation at that moment.
