BMCONVERT command
Converts BIM Linear solids with circular profiles to Mechanical assemblies.
BricsCAD BIM
Method
Select entities to convert and choose the proper styles for pipes.
Options within the command
Pipe
Allows you to select a style for the pipe segment.
Elbow
Allows you to change the styles for the pipe elbows (45 deg and 90 deg).
Reducer
Allows you to change the styles for the pipe reducers (concentric and eccentric).
Splitter
Allows you to change the styles for the pipe tee and pipe cross.
Lists available styles
Note: Use ; to select multiple styles.
Use current
Uses the current style.
SETtings
Opens the Settings dialog box with the Conversion section expanded.
