BMDEPENDENCIES command
Lists all files, containing component definitions inserted in the assembly, in the Command line.
Icon:
Method
The files are automatically listed in the Command line once the command is run.
Note:
- If one of the dependencies is modified (and saved) while the assembly is open,
NEEDS UPDATEis listed. When a dependency needs an update, the command suggests to call either the BMUPDATE command (mechanical entities) or the -XREF command (non-mechanical external references). - If a dependency is renamed or deleted,
NOT FOUNDis listed.
Options within the command
- Mechanical entities
- Lists in the Command line all mechanical entities inserted in the assembly.
- eXternal references and mechanical entities
- Lists in the Command line all external references and mechanical entities inserted in the assembly.
