BMDEPENDENCIES command
Lists all files, containing component definitions inserted in the assembly, in the Command line.
Icon:
Method
The files are automatically listed in the Command line once the command is run.
Related commands
  • BMRECOVER command
  • BMUPDATE command
  • MECHANICALBROWSEROPEN command
