BMEXTERNALIZE command
Converts local components to external components.
Icon:
Local Mechanical components are converted to external components with the Save Mechanical Component dialog box.
Local Mechanical blocks are converted to external references with the Save Block dialog box.
This procedure is repeated for each selected local component.
Options within the command
- Entire model
- A file dialog displays for each local component in the assembly.
- ASk for file names
- Toggles the option to ask for file names of externalized components or to generate them automatically.
- Yes
- File names need to be entered.
- No
- File names are generated automatically.
