BMEXTERNALIZE command
Converts local components (Mechanical blocks) to external components.
Icon:
Local components (Mechanical blocks) are converted to external components with the Save Mechanical Component dialog box.
The external component drawing will inherit the template visual style, layers, and layouts from the parent document.
Local Mechanical blocks are converted to external references with the Save Block dialog box.
This procedure is repeated for each selected local component.
Options within the command
- ASk for file names
- Toggles the option to ask for file names of externalized components or to generate them automatically.
- Yes
- File names need to be entered.
- No
- File names are generated automatically.
- Entire model
- Selects the entire model. The Save Mechanical Component dialog box displays for each local component in the assembly.
