BMRECOVER command
Recovers a broken mechanical structure.
Recovers a broken mechanical structure selected through the Select mechanical component dialog box. The command overwrites the original drawing.
Note: The command differs from the basic AUDIT and RECOVER commands. It is recommended to use BMRECOVER to mend issues with a MCAD drawing.
