BMSHOW command
Shows hidden mechanical components from the drawing.
Shows previously hidden mechanical components inserted in the current drawing.
Options within the command
- show ALl
- Shows all component inserts.
- COmponent name
- Type the component name of the component insert(s) you want to show. This affects all inserts of the specified component.
- Insert name
Type the insert name of the component insert you want to show.
If you want to show a nested component insert (subcomponent insert), first type the insert name of the parent component insert, then the component insert name separated by a forward slash (/).
