BMUNLINK command
BMUNLINK command
Breaks the connection between a component insert and a 3D solid retaining the opening.
Breaks the connection between a component insert (e.g. a Window) and a 3D solid (e.g. a Wall) retaining the opening by selecting the components.
Related commands
  • BMINSERT command
  • BMLINK command
Related information
  • Components and component inserts
