BMVSTYLE command
Changes the visual style of a mechanical block.
Options within the command
by Viewport
Applies the current visual style of the viewport.
Wireframe
Applies the Wireframe visual style.
Hidden
Applies the Hidden visual style.
Realistic
Applies the Realistic visual style.
Conceptual
Applies the Conceptual visual style.
Modeling
Applies the Modeling visual style.
by Name
Applies a named visual style.
All
Applies the visual style to all mechanical block in the drawing.
Insert name
Allows you to type the mechanical block's name to apply the visual style.
Note:
  • Use slash (/) to separate names of nested inserts.
  • Mechanical block names are case sensitive.
