CDORDER command (Express Tools)
Arranges the entities draw order based on their index color.
Icon:
Method
Select the entities you want to arrange. The Color based Draw Order dialog box opens, where you can specify the color priority.
The Color based Draw Order dialog box allows you to specify the draw order of the selected entities based on their index color.
- Color list
- Move up and down buttons
- Re-Order Method
- Draworder Location
Color list
Lists the index colors of the selected entities.
Note: The first color on the list places the entities in the front, while the last color places the entities in the back.
- Move up
- Moves the selected color up in the list.
- Move down
- Moves the selected color down in the list.
Re-Order Method
- Draworder
- Changes the display order of the selected entities using the DRAWORDER command.
- Handles
- Changes the display order of the selected entities by reordering entities in the drawing database.
Draworder Location
- Front
- Places the selected entities in front of the entities that are not specified in the color list.
- Back
- Places the selected entities behind the entities that are not specified in the color list.
- Modify Blocks
- Changes the display order of the entities in blocks.
