CENTERRESET command
CENTERRESET command
Resets centerline and center mark entities.
Icon:
Centerlines are reset by the program when one of the associated lines is moved. Center marks are reset automatically when the associated circle or arc is moved or when their radius or diameter is modified.
Related commands
  • CENTERDISASSOCIATE command
  • CENTERLINE command
  • CENTERMARK command
  • CENTERREASSOCIATE command
  • SELECT command
Related information
  • Centerlines and center marks
