CHPROP command
Changes the properties of the selected entity.
Changes the properties of the selected entities, with fewer options than the CHANGE command. You can change the properties for one or multiple entities.
Note: This command is largely superseded by the properties panel.
Options within the command
Color
Changes the color of the entity.
Truecolor
It allows you to specify the true color by introducing values for colors.
COlorbook
Select colorbook to append.
LAyer
Changes the layer to which the entities are assigned.
LineType
Changes the linetype. Linetype must be loaded into the drawing.
linetype Scale
Changes the linetype scale.
Line Weight
Changes the lineweight.
Thickness
Changes the thickness.
TRansparency
Changes the transparency.
Material
Applies a material.
Annotative
Sets the annotative property.
