CLEANSCREENON command
Makes the drawing area larger by hiding elements of the user interface.
Note: Do not use the numeric keypad. On AZERTY keyboards: do not press the Shift-key when hitting the number key.
Method
Elements in the user interface are hidden according to the values of the CLEANSCREENOPTIONS system variable.
