CLIP command
Clips the display of the selected entity to a specified clipping boundary.
Method
Select an entity to clip it by defining a clipping boundary.
The list of options in the Command line varies depending on the type of the selected entity. You can select one of the following entities: Xref, block, image, PDF, or viewport.
Clipping an Xref or block reference
Options within the Command line when clipping an Xref or block reference are described in the XCLIP command article.
Clipping an image
Options within the Command line when clipping an image are described in the IMAGECLIP command article.
Clipping a PDF
Options within the Command line when clipping a PDF are described in the PDFCLIP command article.
Clipping a viewport
Options within the Command line when clipping a viewport are described in the VPCLIP command article.
