COMMANDLINE command
Opens the Command Line panel.
Opens the Command Line panel to display it in the current workspace. The Command Line panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Command Line can be either floating, docked or stacked.
