COMMUNICATORINFO command
Checks whether the Communicator for BricsCAD add-on is correctly installed and provides a diagnostic report.
Note: The command is available on Windows only.
Starting with V26, the minor versions of BricsCAD and Communicator for BricsCAD should match when available (for example, the Communicator for BricsCAD V26.2.x works with the BricsCAD V26.2.x).
Note: Up to V21, the minor versions of BricsCAD and the Communicator for BricsCAD should also match.
Starting with V21 to V25, only the major versions of BricsCAD and Communicator for BricsCAD need to match (for example, Communicator for BricsCAD V21 works with BricsCAD V21).
Switches to the Prompt History window and then provides a report.
When Communicator for BricsCAD is not installed, then the command reports:
Brief check result: Communicator module loading: FAILED
