CONTENTBROWSEROPEN command
Opens the Content Browser panel.
Opens the Content Browser panel to display it in the current workspace. The Content Browser panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Content Browser panel can be either floating, docked or stacked.
The Content Browser panel offers you a quick and convenient way to open drawings, manage your block libraries, copy dimension styles, place views for your entire DWG files stored on your computer.
- Add Folder…
- Refresh
- Definitions in the selected drawing
- Local Folders tree
- Definitions’ preview
- Description
Add folder…
Displays the Choose a folder dialog box.
Refresh
Select a drawing and press the Refresh button to expand its content (Blocks, Dimension Styles, Model Views).
Select Blocks/Dimension styles/Model views to see the definitions used within the drawing.
You can drag & drop a block onto the current drawing and an Insert Block dialog box will appear.
You can drag & drop a dimension style into the current drawing. If a dimension style with the same name already exists, a Copy / Paste dialog box will appear.
You can drag & drop a model view into the current drawing. This option is available only in Paper Space.
Local Folders tree
Displays the content of a drawing/project. Right-click menus enable you to add or remove folders from within the Folders tree.
Shows a preview of your drawing/block/dimension style.
Displays a description of your selected definition.
