CONVERTGISTOOBJECTDATA command
Converts BricsCAD GIS data from the current drawing to AutoCAD® MAP 3D and Autodesk® Civil 3D Object Data.
Method
Specify the GIS Layer name to convert or convert all GIS Layers from the current drawing.
Options within the command
- Convert all
- Converts all the GIS Layers in the drawing.
Note: The Object Data can be viewed and edited directly in the Properties panel.
