CONVTOMESH command
Converts entities to mesh entities.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_INTL/command-reference-all.png)
Converts valid 2D and 3D entities to Mesh entities. Valid entities include:
- 3D Solid
- Surface
- Polygon Mesh
- Region
- Closed Polyline
Method
Select a valid entity then select another valid entity or press Enter to complete the command.
Note: The BIM data and GUID are maintained after converting.
