CONVTOSURFACE command
Converts entities to Surface entities.
Converts valid 2D and 3D entities to Surface entities. Valid entities include:
- 2D Solid
- 3D Solid
- Region
- Open Polyline with non-zero thickness and zero width
- Line with non-zero thickness
- Arc with non-zero thickness
- Circle with non-zero thickness
- Mesh
- Planar 2D Face
Method
Select a valid entity then select another valid entity or press Enter to complete the command.
Note: The BIM data and GUID are maintained after converting.
