COPYBASE command
COPYBASE command
Copies entities to the Clipboard.
Icon:
Copies entities to the Clipboard with a base point for pasting into the same drawing or another drawing.
Note: When you paste entities copied with the COPYBASE command, it uses a user-defined base point.
Related commands
  • COPY command
  • COPYCLIP command
  • COPYHIST command
  • CUTCLIP command
  • PASTEBLOCK command
  • PASTECLIP command
  • PASTEORIG command
  • PASTESPEC command
Related information
  • Copying entities
  • Grips editing
Octave
