COPYEDATA command
Copies extended entity data from one entity to others.
Icon:
Method
Enter the name of the application to which the entity data belongs, select the entity from which to copy Entity Data and one or more entities to which to copy Entity Data (that will receive the edata).
Extended Entity Data can be created with EDITEDATA command.
Options
- ? to list application names
 - Lists the names of applications loaded in the current drawing.
