COPYTOLAYER command
Copies entities to another layer.
Creates duplicates of selected entities on a layer specified by the user. You can specify a different location for the duplicated entities.
Method
There are two methods to copy to layer:
- Select entity on target layer.
- Select target layer in the Copy to Layer dialog box.
Options within the command
- Name
- Displays the Copy To Layer dialog box that allows selecting a target layer.
- Displacement
- Specify the displacement vector (the distance at which to position the copy). 'Vector' means that you specify the distance and angle at the same time.
Note: When Dynamic Input Mode is active, you can type a
distance and angle in the dynamic input fields.
