-DGNEXPORT command
Exports the current drawing to MicroStation DGN file (*.dgn) format via Command line.
Method
Specify the full path and file name for the exported DGN file.
Note: Type ~ (tilde) to display the Export Drawing As dialog box, which allows you to specify the folder and the name for the DGN file.
Options within the command
- convert to DGN
- Converts reference to DGN.
- keep as DWG
- Keeps reference as DWG.
- Bind
- Binds reference file to the parent DGN.
- Detach
- Detaches external reference.
