-DWGUNITS command
Sets the units and the drawing unit display format for the current drawing and decides how to scale entities in the Model and Paper spaces based on the new units.
Method
Choose a drawing unit and the drawing unit display format, and decide whether to scale entities in the current drawing to reflect unit changes and whether to scale entities in Paper Space.
Options within the command
- Drawing units
- Lists available drawing units on the Command line.
- Drawing unit display formats
- Lists the available drawing unit display formats on the Command line.
- Scale entities from other drawings upon insert?
- Allows you to decide whether to scale entities from another drawing when inserting.
- Match INSUNITS to drawing units?
- Allows you to decide whether to match INSUNITS with drawing units.
- Scale entities in current drawing to reflect change in units?
- Allows you to decide whether to scale entities in the current drawing to reflect the change in unit.
- Include entities in Paper Space?
- Allows you to decide whether to scale entities in Paper Space.
