DDFILTER command
DDFILTER command
Creates a selection set of the entities.
Note: This command is superseded by the SELECT command.
Creates a selection set that include the selected entities, so you may access it by entering "P" (previous) the next time a command prompts you "Select entities."
Related commands
  • DDGRIPS command
  • DDSELECT command
  • PROPERTIES command
  • SELECT command
Related information
  • Selecting BIM entities
  • Selection methods
Octave
