DELETESKETCHFEATURE command
Deletes the sketch features and their corresponding solids.
Allows you to delete sketch features and all their dependencies.
Note: The EXTRUDE, LOFT, SWEEP, and REVOLVE commands and their children features SUBTRACT, and UNITE, create Features when the CREATESKETCHFEATURE system variable is ON. They are available in the Mechanical Browser panel (for example, Extrude_1, Loft_1).
Method
Specify a comma separated list of Sketch Based Features (for example, Extrude_1, Loft_1) to be deleted. Otherwise, the command will delete all existing Sketch Based Features, if there is more than one.
Note: Deletes all corresponding sketch features and their corresponding solids in the current drawing.
