DETAILSPANELOPEN command
Opens the Details panel.
Opens the Details panel to display it in the current workspace. The Details panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Details panel can be either floating, docked or stacked.
The Details panel allows you to view details, add tags to details, propagate and adjust details.
- Home
- Details library
- Filter
- Menu
- List view or Grid view
- Create detail
Home
Returns the details library to the home screen.
Details library
The details library is organized by categories. Select a category to view its details.
When you click a detail, the View Detail dialog box appears (see the View Detail dialog box article).
Filter
Displays the filter options. Here you can search the library for specific details using tags. You can add one or more tags at once to filter your result and select all matching details.
- Reference solid tags
- General tags
- Filters the details based on Reference solid tags. Click the Add detail tags option, then select a filter from the drop-down list. Use the search field to narrow down the list.
- General tags
- Filters the details based on General tags. Click the Add detail tags option, then select a filter from the drop-down list. Use the search field to narrow down the list.
Menu
- Generate thumbnails
- Generates or updates the thumbnail images of all details.
- Manage libraries
- Opens the Settings dialog box to change the details directory path.
Displays the details in either a list view or a grid view, depending on the selected option.
Create detail
Launches the BIMCREATEDETAIL command.
