DIMBASELINE command
Creates stacked dimensions from the same baseline.
Icon:
Alias: DBA, DIMBASE
Creates stacked linear, angular or ordinate dimensions from the same baseline as an existing dimension. The dimensions are based on the current dimension style and the dimension spacing is specified by the DIMDLI variable.
Method
This command has 2 methods to begin creating baseline dimensions:
- Origin of next extension line
- Select starting dimension
Options within the command
- Creates baseline dimensions from the last linear, angular, or ordinate dimension by specifying a point for the next extension line.
For linear and angular dimensions, the first extension line of each baseline dimension coincides with the first extension line of the previous dimension.
Note: Continue placing dimensions until you press Enter to end the command.
- Existing dimension
- Allows you to select an existing linear, angular, or ordinate dimension.
- Undo
- Undoes the last dimension and continue drawing from the previous dimension.
