DIMBREAK command
Breaks dimension lines, extension lines, and leaders at the locations where they cross other entities.
Icon:
Allows breaking entities such as dimension lines, extension lines or leaders by a certain object and it can also remove breaks.
The dimension entity can be broken on different entities: the dimension line itself (1), on the extension line (2) or on the leader (3).
Options within the command
- Multiple
- Allows multiple dimension entities to be broken in the desired spots.
- Auto
- Breaks all the selected dimension entities at all intersections found with other entities.
- Remove
- Removes all dimension breaks from the selected dimension entities.
- Manual
- The width of the dimension break can be manually defined. This option is not available in Auto mode.
