DIMCONTINUE command
Creates dimensions in a continuous line or arc.
Icon:
Alias: DCO, DIMCONT
Creates a continuous line or arc from an existing linear, angular, or ordinate dimension. The dimensions are based on the current dimension style.
Method
This command has 2 methods to begin creating continuous dimensions:
- Origin of next extension line
- Select starting dimension
Options within the command
- Creates continuous dimensions from the last linear, angular, or ordinate dimension by specifying a point for the next extension line.
For linear and angular dimensions, the first extension line of each continuous dimension coincides with the second extension line of the previous dimension.
Note: Continue placing dimensions until you press Enter to end the command.
- Allows you to select an existing linear, angular, or ordinate dimension.
- Undo
- Undoes the last dimension and continue drawing from the previous dimension.
