DIMJOGLINE command
Applies or removes a jog line to a linear or aligned dimensions.
Icon:
Applies a jog line to linear or aligned dimensions. The dimension should represent the actual dimension.
Method
Select the linear or angular dimension to add a jog and specify the jog location.
Options within the command
- Remove
- Removes the jog of a linear or alined dimension.
