DIMLINEAR command
Creates a linear dimension.
Icon:
Alias: DIMHORIZONTAL, DIMLIN, DIMROTATED, DIMVERTICAL, DLI
Creates a linear dimension that is horizontal, vertical, or rotated. The dimension is based on the current dimension style. Options allow you to specify the angle and contents of the dimension text.
Method
This command has 2 methods to begin creating a linear dimension:
- Origin of first extension line
- Select entity
Options within the command
- Allows you to begin creating a linear dimension by specifying a point for the first extension line.
- Origin of second extension line
- Specifies a point for the second extension line.
- Angle
- Specifies the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- Text
- Allows you to enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
- Horizontal
- Specifies the location of the dimension to place it in the drawing. This creates a horizontal dimension regardless of how the endpoints are aligned.
- Vertical
- Specifies the location of the dimension to place it in the drawing. This creates a vertical dimension regardless of how the endpoints are aligned.
- Rotated
- Specifies an angle of the dimension line.Note: The dimension is rotated from its default (vertical or horizontal) location by the specified angle.
- Location of dimension line
- Rotated dimension
- Angle of dimension line
Specify the location of the dimension line. If the two extension points you specified are aligned vertically or horizontally, you are restricted to placing a vertical or horizontal dimension, respectively. If the two extension points you specified are not vertically or horizontally aligned, you can drag the cursor to place either a vertical or a horizontal dimension.
- Horizontal dimension
- Vertical dimension
- Select entity
- Allows you to select an entity (line, polyline segment, arc, or circle) to dimension.
When selecting a line, the endpoints of the line are used for the extension origins.
When selecting an arc, the endpoints of the arc are used for the extension origins. When selecting a circle, the quadrants of the circle are used for the extension origins.
- Line entity
- Circle entity
- Arc entity
